Problem when print front and rear in A3 paper
  • dega
    • May 2021
    • 2
    [Misc] Problem when print front and rear in A3 paper
    hello everyone, I have a problem with a c280.
    When I print front and back in a3 format I hear a "stok" noise and the sheet is creased.
    In a4 format everything is ok.
    Possible solutions.
    Thank you
  • GIUBOSS
    • 1437
    Re: Problem when print front and rear in A3 paper
    Possible solutions.
    Thank you
    where exactly do you find it jammed? Have you tried putting the A3 in another input tray? Are rubber rollers new?
    • dega
      • May 2021
      • 2
      I tried in another drawer but the result is the same.
      the problem is at the end of the sheet. It seems that when he turns the paper, too much is taken. rollers aren't new.
      • GIUBOSS
        • 1437
        check the belt
        • tsbservice
          Field tech
          • 8053
          Try another paper. If you're using thick paper tell the machine gsm weight.
          • Synthohol
            Certified Konica Expert
            • 5892
            stop the print at different intervals and see WHEN the crease occurs.
            • tulintron
              • Jul 2014
              • 668
              I agree with Synthohol. Stop the print and see where the problem occurs. Photo of the problem sheet would not be bad
