C3350i eat toner
  • suomi
    • Oct 2008
    • 152
    C3350i eat toner
    Especially the magenta toner wears out quickly and fills the waste toner box...No error codes. Print quality is good
  • robinsonad86
    • Aug 2014
    • 67
    Re: C3350i eat toner
    There's a bulletin about this on the KM tech site. Replace image unit following instructions and fw update
    • emujo2
      • Mar 2017
      • 1579
      Check your TCR levels..if they are very high you will need to update f/w replace the IU and run the out of the box setup. You should be good to go after this (assuming you see very very high TCR ratios). E
      • copier tech
        • 8169
        I've had this exact issue.
        The resolution is to update the firmware (no surprise it's a KM) then run initialisation + stabilise with the paper tray out.
        • ionutkok
          • Nov 2012
          • 24
          Chek TCR value ( aprox 6.5 % is normal) for every color ! Update last firmware !
          • tsbservice
            Field tech
            • 8020
            As much as I like KonicaMinolta machines the ultimate resolution is to buy color A4 Ricoh MFPs. A4 color models simply aren't KM mainstream.
            • ionutkok
              • Nov 2012
              • 24
              Which models? Some are more successful others are not. But for any model there are "good" service solutions.
              I.M.
              • copier tech
                • 8169
                Totally agree, when I install a new Ricoh MFP I very rarely need to go back.
                • suomi
                  • Oct 2008
                  • 152
                  Paper tray out..Why??
                  I replaced the magenta drum unit. Update firmware GC2-E9. Clean the toner filter(full off magenta toner), change new M toner and waste toner box.
                  Now just waiting to see what happens...
                  • B0265
                    • Jan 2007
                    • 718
                    • Sysco
                      • Mar 2010
                      • 43
                      Same issue in my field machines with C3300i.
                      Print halftone pattern and if it is ok update fw.
                      The only help, if you can't see the first error messages when drop the machine which is 2555 or 2553 the fw. update to E9 and
                      change the IU unit to new..
                      If you catch the problem in the first time and not updated the fw version you need update to this and hope it's enought to the machines
                      not dropping to the developer from the IU unit.
                      • suomi
                        • Oct 2008
                        • 152
                        The problem is that the device eats toner (magenta on this case). 3000 pages and 2 colors(magenta) and 2 waste toner boxes (full magenta)...Other colors OK(60%)
                        Print quality good. No error code. Toner filter full magenta toner (vacuumed all pipes etc)
                          I'm surprised no one has asked this question!
                          are they using genuine OEM toner or some turd party toner?
                          • B0265
                            • Jan 2007
                            • 718
                            Have u checked the TCR values?
                            • tsbservice
                              Field tech
                              • 8020
                              Not this time Phil. Those models are flawed even new machine will eat its install toners.
