C3350i eat toner
  • B0265
    • Jan 2007
    • 718
    #16
    Re: C3350i eat toner
    I'm surprised no one has asked this question!
    are they using genuine OEM toner or some turd party toner?
    That is a relevant question, but in this case it is a known problem even if if you use oem toner.
    • copiertec
      • Jan 2016
      • 2211
      #17
      My first thought, when seeing the post.
      • suomi
        • Oct 2008
        • 152
        #18
        20 years konica service now. I use orginal toner.
          ok thanks guys... i've been spanked enough ;-)
          • Sysco
            • Mar 2010
            • 43
            #20
            Originally posted by suomi
            The problem is that the device eats toner (magenta on this case). 3000 pages and 2 colors(magenta) and 2 waste toner boxes (full magenta)...Other colors OK(60%)
            Print quality good. No error code. Toner filter full magenta toner (vacuumed all pipes etc)
            Update FW.
            • danifuenca
              • Oct 2013
              • 33
              #21
              We have a advice from KM Support to reseting PWB (remove and place again sure all contacts are in correct position)in all machines C3350i/C4050i because high toner consumtion
              • avecosat
                • Jun 2012
                • 305
                #22
                Always change a IU make a Image Stabilization
                • Albonline
                  • Sep 2008
                  • 1151
                  #23
                  These models need to have gradation, done properly, at setup or they will never be right. save replacing all units and doing a proper setup.
                  • jwai
                    • May 2018
                    • 509
                    #24
                    now i have one C450i also ate toner.
                    one new Y toner only used 1 week and about 10k copies.
                    the waste bottle are filled with Y toner.
                    • robinsonad86
                      • Aug 2014
                      • 67
                      #25
                      Toner or dev?
                      • jwai
                        • May 2018
                        • 509
                        #26
                        Originally posted by robinsonad86
                        Toner or dev?
                        Toner.
                        New Y toner bottle got empty only 3 days and several thousand printout!! ( mainly office documents )
                        It flowed to waste bottle, and a thin toner coating on the surface of Y drum.
                        Exchanged the drum unit with M still the same.
                        TCR all are 6.XX%, ATVC CM are 20 K is 22 however Y is 16.
                        • mascan42
                          • Oct 2008
                          • 485
                          #27
                          I'm having this with the yellow toner on multiple machines, all the same account. Yellow TCR is low, but only because customer keeps running it with the empty toner bottle, until it eventually codes out. Replacing the IU only seems to fix it temporarily.
                          I can't find any bulletin referring to this. What level firmware addressed the problem? All machines are at least G00-B5. Reluctant to update in the field because of the customer's custom UI.
                          • jwai
                            • May 2018
                            • 509
                            #28
                            Now it works with G00-B6.
                            • Synaux
                              • Mar 2012
                              • 1224
                              #29
                              C450i eat toner
                              Hrm.... okay?
                              • jwai
                                • May 2018
                                • 509
                                #30
                                Originally posted by Synaux
                                C450i eat toner
                                Hrm.... okay?
                                not yet, i added a bit y toner and took toner replenishing, the y tcr rised to 6.8%.
                                no toner coating on y drum but the tcr of c and m changed to 0.0X%!
                                got tcr toner supply they raised to 5.X% but p5,6,8 displayed.
                                m toner coated on transfer belt surface.
