BizHub c253
  • PlasticPig
    BizHub c253
    Newbie, so apologies if this has been dealt with before. Did a search but couldn't find anything.
    We have a c253. I'm looking for a solution to an Auto paper select problem. The trays are set like this...
    Tray 1 - A4 plain paper
    Tray 2 - A3 plain paper
    Tray 3 - A4 letterhead
    Tray 4 - A4 letterhead
    We need to be able to let the copier submit jobs using Auto tray select as we often switch between A3 and A4. However, if Tray 1 runs out of paper, the Auto setting redirects to Tray 3 letterhead. It seems to recognise the size difference (by not selecting Tray 2), but it doesn't recognise that we've set this Tray 3 to letterhead.
    Is there any way of stopping the copier from Auto selecting the wrong paper type? Tried the manual but I've seen clearer mud.
  • kingarthur
    • 1327
    select "utility", "user setting", "system settings", "papertray settings", "auto tray settings", "tray priority" & then set up how you want them to select. Also check "no matching paper in tray setting"
    • copytechman
      • Nov 2008
      • 929
      You may also actually set that trays paper type to be letterhead or special paper and the machine won't select it automatically either.
      Regards!
      A.
      • PlasticPig
        Kingarthur,
        I changed the priority from a high to low of 'Tray 1, Tray 2, Tray 4, Tray 3' to just 'Tray 1'.
        Now it asks to load paper. Problem solved.
        Many Thanks and Best Regards,
        PlasticPig
        • PlasticPig
          Just an update...
          Of course, setting it to just Tray 1 screwed up the Auto select for either A3 or A4. Took me a little while to work this out as I'd been looking at the Printer Paper Settings and thought I'd messed it up there (I was looking to see if there was a letterhead setting - there's not one at the printer, only at the printer driver on the server - it only says eg 'A4'). All I had to do was add Tray 2 into the Auto list. So now I have Auto select to either A3 or A4, and we have to point to any other tray to get either letterhead or bypass.
          PlasticPig
          • copytechman
            • Nov 2008
            • 929
            A C253 right? Every one of these that I have seen has a plethora of special paper settings @ the machine. Press the paper button on the touch screen then select the tray then press the paper (type) settings off to the right side.. It should present ya with a pile of choices including letterhead and special papers for your inside trays... when u select one the tray will have a special indicator beside the size on the tray on the paper selection screen. And thats only one way to exclude a tray from the auto selection functions.
            Regards!
            A.
