c750i DF-703 feed gear not engaging
  • tmmdmmm
    • Apr 2021
    • 173
    [Jamming] c750i DF-703 feed gear not engaging
    Hello all! Have a brand new c750i in the field. Gears are not lining up when the top door latches closed. Not seeing any way to adjust the Drive assy closer to the feed gear, nor adjust/shim the feed gear closer to the drive assy. Also not finding a way to adjust either side of the top door's latch independently of the gear or the pin it gets latched to independently of the drive assy to have it closed slightly more. Putting a little pressure on the door lets paper feed, and I have a temporary solution by attaching some mylar underneath the pin, effectively lowering it
    Has anyone else seen this yet?
    • 23009
    Re: c750i DF-703 feed gear not engaging
    Check the pins that the door swivels on at front & back. I suspect one or both are bent ... maybe during delivery?
    • rrrohan
      • Sep 2011
      • 1977
      yeah i had this problem on a 958's as well. just bush mechanic and bent the pins a but so it locks tighter
      • Albonline
        • Sep 2008
        • 1151
        I have (fixed) lots of brand new ones this way. the pins are a set of 4 2 alignment 2 latches. also the framework around the driveshaft for that gear gets out of square.
