bizhub C250i foggy backgroud printout
  • jwai
    • May 2018
    • 507
    Hi everybody,
    One customer reported that the color printout has a bit foggy background, compare with B/W one.
    The color drums have 60% something and 30% something on black drum.
    The machine takes 40K color and 140K black counters.
    Any idea about this issue? thanks.
  • Synthohol
    Certified Konica Expert
    • 5804
    Re: bizhub C250i foggy backgroud printout
    i dont see anything wrong.
    you can always reset and stabilize then do the gradations 3 times each and see if it changes but frankly, im missing where the problem is.
    • jwai
      • May 2018
      • 507
      Sorry, I sent a new sample for reference.
      • CP-1015
        • Nov 2020
        • 308
        Is your cyan TCR-value ok?
        • Dickie
          • Nov 2011
          • 190
          I believe there is a firmware upgrade to cure a problem with too much cyan.
          A previous firmware upgrade caused the issue and it was then upgraded again to cure the issue
          This was on Develop but I assume KM initiated it.
          • Albonline
            • Sep 2008
            • 1144
            the cyan developer looks over toned. what do the halftone outputs look like?
            • Cantechman
              • Nov 2008
              • 227
              Originally posted by jwai
              Hi everybody,
              you can try this:
              change switch 153 bit 6
              under pcl driver:
              quality tab/quality adjustment/other/turn pure black off
              • jwai
                • May 2018
                • 507
                CYMK all 6.XX%
                • Synthohol
                  • 5804
                  before all that, try just simply calibrating it like i suggested above.
                  • tsbservice
                    Field tech
                    • 7981
                    What's FW version? Your threads seems always lack valuable/basic information.
                    Pulling other tech teeth is so much uncomfortable
                      Hell the " Dentist " doesn't mind one bit.. for those that get queasy at the sight of blood don't watch![emoji38][emoji28][emoji1787]
