Konica C224e reboots, SSDB?
  • jonbonse
    • Jun 2009
    • 737
    Hi all
    One of our c224e's has the rebooting with 2 shark fins. I have the SSDB on order but don't have the SSD firmware to load...
    I understand I need to fit the SSDB then load SSD firmware.
    Is this correct? If so, I'm hopeful some has the firmware?
    TIA
    • 23010
    Re: Konica C224e reboots, SSDB?
    AFAIK it comes fully loaded. =^..^=
    • jonbonse
      • Jun 2009
      • 737
      Thanks!
      I have replaced the SSD Board before on a different machine doing the same thing but it made no difference.
      • tsbservice
        Field tech
        • 8079
        1. Replace SSDB.
        2. Install the firmware.
        Done.
        • jonbonse
          • Jun 2009
          • 737
          1. Replace SSDB.
          Done.
          Thanks, I just need the SSDB firmware then which is the only bit I don't have 😩
          • B0265
            • Jan 2007
            • 718
            1. Replace SSDB.
            2. Install the normal firmware, the latest SSD fw should already be on the SSD board.
            • jonbonse
              • Jun 2009
              • 737
              Originally posted by B0265
              1. Replace SSDB.
              Ah perfect! Thanks a million 👍🏻
              • REGSIS
                • May 2016
                • 440
                I always install latest Mass production FW which is M1 for this model. It has SSD FW in the package.
                • jonbonse
                  • Jun 2009
                  • 737
                  Thank you
                  The latest full firmware I have is named 'A5C10Y0-F000-G20-M1-970'.
                  I'm guessing as it has M1 in the name I'm all good...
                  • copier tech
                    • 8236
                    Originally posted by jonbonse
                    Thank you
                    Firmware Readme C224e C284e C364e GDP-M1.pdf
