Drum Scratched
  • emujo2
    • Mar 2017
    • 1579
    [Misc] Drum Scratched
    had an account with micro scratches on the K drum,,Less than 5K prints. had to replace drum, could not find a reason for the scratches. Went back out 1 week later, same micro scratches on new K drum and now the same on CMY drums. After some research we found that the internal temp sensor was malfunctioning, showing 0 degrees. machine was over compensating for what it thought was a freezing environment. Hope I can save someone a good chunk of wasted $$$. E
    • 23010
    Re: Drum Scratched
    Thanks for sharing!
    I had a C754e that kept buffing the gloss off the black drum. It turned out that there was a problem with the black developing unit. It was so full it was forcing developer out the doctor blade gap. There was a mound of developer that piled up on top of the developing unit, buffing the surface off the drum. =^..^=
    • tsbservice
      Field tech
      • 8053
      Re: Drum Scratched
      Perhaps knowing the model will be of use. I will guess it's C250i
      • emujo2
        • Mar 2017
        • 1579
        Re: Drum Scratched
        Yes, I series. C450i to be exact.
        • jwai
          • May 2018
          • 517
          Re: Drum Scratched
          i series, frequently replaced drums......
          • tech51
            • 846
            • tsbservice
              Field tech
              • 8053
              Re: Drum Scratched
              MML list is your friend. Study it all anomalies will present there.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4765
                Re: Drum Scratched
                Why couldn't K/M leave well enough alone. Just stayed with the 4 series style drum. Probably answer my own question, I'm sure it's because they know the consumable life counters were turned off on the 4 series and drums & other items could go 2-3 cycles before changing. They must of realized they weren't making enough $$$ on the consumables so they go to a piece of crap drums with a PCR!
                Little does Kon/Min know a move like this will hurt them in the long run when the end user upgrades and wants NO part of a consumable money pit and buys different OEM!
                • Synaux
                  • Mar 2012
                  • 1224
                  Re: Drum Scratched
                  So I get that the machine thought it was freezing and regardless of the notion a code should have been displayed/thought of on the development-side (you know, because would be a very rare operating environment).
                  What actually caused the scratches? xbelt running 24/7 or something?
                  • emujo2
                    • Mar 2017
                    • 1579
                    Re: Drum Scratched
                    Possibly an overcharge of the pre charge roller. Not 100% certain.
