new c257i error c9402
  • slot
    • Jul 2008
    • 341
    Not sure if anyone can help I have set up a new c257i today and it all worked ok installed d/f etc and ran through our setup sheet all ok and ran some test sheets
    the last thing I did was upgrade the firmware from the KM website now the copier produces black copies and the led lamp wont come on with error c9402 I have rechecked the firmware and it is the correct one. any advice would help as im not the best KM engineer I mainly deal with Ricoh machines but I have set up loads of KMs im trying to avoid DOA the machine as they are taking a long time to come in. thanks for any advice
  • tsbservice
    Field tech
    • 8026
    Re: new c257i error c9402
    Direct sun shines the machine at some time ?
    • copier tech
      • 8179
      Sounds like a nightmare.
      Can you downgrade the firmware maybe the version you installed has a bug?
        • 23009
        What model document feeder? Is it the correct match? =^..^=
        • splblazer91
          • Jul 2014
          • 204
          Downgrade FW. There are different models of the CCD assy that arent always compatible,
          • tsbservice
            Field tech
            • 8026
            Isn't it documented in FW update doc/pdf?
            • splblazer91
              • Jul 2014
              • 204
              Yup
              • tsbservice
                Field tech
                • 8026
                Yup
                Agree. Sometimes reading required.
