FS532/SD woes
  • emujo2
    • Mar 2017
    • 1580
    [Misc] FS532/SD woes
    11x17, 5 internal pages are plain, outer page is 100# coated text. Cover is hanging up and getting folded about 4 inches off, internal 5 pages are folded properly. I swapped another FS532 (SD has never been used) and I get the same result. I can get 5-6 out that are correct, then the coated stock starts dragging and gets the bad fold. I can run the job directly to an out put tray and throw the job on a table, all pages fan out so it's not static. I'm leaning towards the recent start of rainy season and possible humidity problems but I'm sure I will have a rough time selling this. Any ideas?
  • Synthohol
    Certified Konica Expert
    • 5458
    Re: FS532/SD woes
    Please double check the specs, 100lb text is 148gsm which is past the 91gsm limit of the folding unit. Even if you used a cover inserter it may still give issues.
    But again please check the documentation as I think it's being used out of spec.
    • emujo2
      • Mar 2017
      • 1580
      Re: FS532/SD woes
      According to what I read..Cover can be 50 to 300gsm, this stock is 155 gsm. 5 sheets inside. specs say coated is acceptable.
      • Synthohol
        • 5458
        2 / 25 lb Bond or more, and cover paper of 92 g/m22 / 25 lb Bond or more, and cover paper of 92 g/m2 / 25 lb Bond in PI tray insertion mode)
        6 sheets to 10 sheets stapled: 23 sets (15 sets if using cover paper of 92 g/m2 / 25 lb Bond in PI tray insertion mode)
        11 sheets to 25 sheets stapled: 15 sets (10 sets if using cover paper of 92 g/m2Paper Capacity Available for Use
        • emujo2
          • Mar 2017
          • 1580
          Re: FS532/SD woes
          This is from the C6085 guide..
          25.3 Type of paper
          25.3.1 Saddle stitching mode
          Paper size*1 SRA3, A3, B4, ISOB4, SRA4S, A4S, B5S, ISOB5S
          13 x 19*4, 12 x 18, 11 x 17, 81/2 x 14, 81/2 x 11S
          8 1/2 x 13, 8 1/4 x 13, 8 1/8 x 13 1/4, 8 x 13
          8K , 16KS
          Wide paper (A3W, A4SW, B4W, B5SW, 12 x 18W, 11 x 17W, 81/2 x 11SW)
          Custom size Minimum 120mm x 240mm, Maximum 331 mm x 488mm
          Applicable paper Plain, Fine, Color, Coated, PrePrinted, Book/News, Plain-rough, Textured (same as the main body)
          Paper weight *1 Inside paper: 50g/m2 to 216g/m2
          Cover: 50g/m2 to 300g/m2
          Maximum saddle stitching sheets Paper weight Sheet
          The paper width is 279.4 mm or
          longer in the sub scan direction.
          The paper width is shorter than
          279.4 mm in the sub scan
          direction.
          40 g/m2 to 49 g/m2 - -
          50 g/m to 261 g/m2 25 sheets -
          62g/m2 to 74g/m2 20 sheets -
          75g/m2 to 80g/m2 20 sheets 10 sheets
          81g/m2 to 91g/m2 16 sheets 10 sheets
          92g/m2 to 105g/m2 5 sheets 5 sheets
          106g/m2 to 135g/m2 5 sheets 5 sheets
          136g/m2 to 162g/m2 5 sheets 5 sheets
          163g/m2 to 216g/m2 5 sheets 5 sheets
          217g/m2 to 244g/m2 Cover only -
          245g/m2 to 300g/m2 Cover only -
          301g/m2 to 350g/m2 - -
          1/2 fold specs are the same..
