C368 3003 30-03 jams folding under fuser unit
  • Kwkoeb
    • 2
    Hello all, I am having 3003 jams. Machine has about 500k on it. Seems to be worse from large capacity tray 3 but will do it from tray 1 also. Folds paper over in a loose fold right below fuser. Will jam like this every 50-100 copies.
    any ideas??
    • 23010
    Re: C368 3003 30-03 jams folding under fuser unit
    30-03 codes are usually caused by either the exit sensor over the fuser or the exit clutch, but in both cases the paper makes it through the fuser.
    I'm going to guess that you have up to (9) pieces of paper jammed in the fuser, stalling the fuser drive motor. Many endusers have no idea that the little guide on the top of the fuser lifts up. =^..^=
    • Kwkoeb
      • 2
      no paper is jammed in the fuser. What sensor are you referring to? PS number?
      thanks
        • 23010
        PS3.
        • REGSIS
          • May 2016
          • 435
          any ideas??
          J30-03 paper doesn't reach fuser exit sensor
          Before all on 500k check for rust on fuser interlock (right side door). If so, replace paper exit clutch.
          1. Damp paper?
          2. Check guide on top of ITB
          3. Check fusing unit enterance guide
          4. Remove registration unit (IDC sensor unit with registration roller and clutch)
          5. Replace registration clutch and registration sensor.
            • 14972
            Remove the fuser and look very closely at the black fuser entrance guide. I have seen several times where the enamel coating will peel back and catch paper.
            • tech51
              • 846
