Bizhub 367 External USB
  • Zesti
    • Jun 2009
    • 308
    [Misc] Bizhub 367 External USB
    Hi there,
    There is this 367, not detecting external USB. External USB settings in admin settings not showing. Tried to detect USB from state conformation showing NG...... Any idea?
  • Synthohol
    Certified Konica Expert
    • 5823
    Re: Bizhub 367 External USB
    It's rare that a drive over 8gb is recognized. Have you tried a 2g or 4g?
    • Synthohol
      • 5823
      Also if the hdd is not "set" there are no USB options I believe.
        • 23007
        Has the cable been disconnected? As a redundancy, in certain environments the external USB port is disabled, and the cable disconnected. =^..^=
        • allan
          RTFM!!
          • 5462
          Also could be disable under system settings > userbox settings > external memory settings.
          Whatever
          • Zesti
            • Jun 2009
            • 308
            Thanks all,
            Everything has been accounted for... A 32 GB FAT32 drive is accessible on another BH367 machine.
            There is no HDD in other machine also but USB is detecting. If HDD is not present even then it should access USB and save to it at least.
            The option for External memory is not showing.....is there any SW settings for disabled USB ports.
            Once there was a problem in a BH367 machine and I switched the USB port on the MFP board and that was working.
            • tsbservice
              Field tech
              • 8008
              Start from scratch do Initialize all.
