Konica Minolta Marketplace with a c458
  • adecanmin
    • Oct 2010
    • 316
    Gentlemen
    I don't know a darn thing about it. I have a customer that wants to scan to google drive from the copier. What I've gleaned so far is go to the marketplace have the customer purchase the app for $99.00 Some kind of token is issued. Once marketplace in enabled on the copier is the app installed from the copier panel or through the computer using the MarketPlace installer? Is this app worth $99.00? Are there any alternatives?
  • progoffice
    • Nov 2008
    • 336
    Re: Konica Minolta Marketplace with a c458
    Once Marketplace is installed, you download and install the apps from the copier panel. You can usually run a trial version of the app to see if it's worth the money. As an alternative, you can install Google Drive's Backup and Sync software to your customer's computer and simply set up a SMB scan folder within the primary sync folder and the file will automatically upload to his/hers Google Drive account.
    • adecanmin
      • Oct 2010
      • 316
      thanks
      • Rewind!
        Somehow it works....
        • Jan 2019
        • 89
        Originally posted by adecanmin
        thanks
        This is way more efficient than using the market place app. Theres a big difference in process speed (Start scan to finish) as theres less buttons straight to SMB and just having drive sync.
        JC
        • copier tech
          • 8169
          Gentlemen
          A much easier & cheaper way is to install Google drive on the clients PC then simply sent up SMB to scan to the google drive folder it will then sync with the cloud & upload the scanned files.
          • adecanmin
            • Oct 2010
            • 316
            I'm starting to see that. I would like to get the demo working for my own knowledge. There is one stumbling block. The demo is installed in marketplace. I have to log into google from the copier. It says could not sign you in. This browser or app may not be secure. Do I have to create a self signed certificate?
