Biz C224e misfeed
  • femaster
    • May 2011
    • 1485
    #16
    Re: Biz C224e misfeed
    Originally posted by copyman
    What about scuffing up the shaft where one ways go, I use scotchbrite pad? I always do this when replacing one ways.
    I can honestly say I've almost never replaced a one way. Generally a cleaning of the one way with alcohol and scuffing of the shaft with scotchbright is all that is needed to get things back to operational. I do this every time I change out the tires.
    • rrrohan
      • Sep 2011
      • 1977
      #17
      i dont scuff. my logic is if it helped it would come like that out of the factory
      • femaster
        • May 2011
        • 1485
        #18
        If you want to get technical, they do come out of the factory like that. The metal shafts are not perfectly smooth from the factory, they have fine grooves in them from being turned in a metal lathe during production. The shafts eventually get "polished" completely smooth under the one ways and then the one way will begin to slip on the shaft instead of griping it. If someone were to simply clean the one way, or even replace it, it would still slip as the shaft is too smooth for the one way to get a consistently good grip on it. I bring back that slight coarseness to the shaft surface, by scuffing it with Scotchbright, which prevents the one way from slipping. By scuffing, we are not talking about creating deep gouges in the surface, only a matter of roughing up the surface a bit.
        If it didn't work I wouldn't bother doing it, as there is no point in doing more work than is necessary. If I didn't scuff the shafts the one ways will generally start slipping before the new set of tires reach half their life cycle. With scuffing, I never have to worry about them slipping at all, which means less service calls and a happier customer. Because of this, I'll continue to scuff the shafts where the one ways ride, and if not scuffing yours works for you, have at it.
        • rrrohan
          • Sep 2011
          • 1977
          #19
          i get the logic i used to do it on the old C353's and C220s but havent done it since the 4 series released. i think they re designed the bearings which must of fixed it cause they used to be blue and now are all black
          • Synaux
            • Mar 2012
            • 1224
            #20
            Well Scotchbrite (which contains both Aluminum oxide and Titanium oxide) it is rated at around 1000 grit. (google told me so).
            Those that have ever done any wet-sanding know that is not much.
            Especially on a metal shaft (in this scenario, I assume 304 stainless).
            More likely what you are accomplishing is clearing debris off the shaft:
            In particular, the metal and plastics from the bearing embedding itself into the microscopic surface of the shaft.
            In fine, there is almost no reason not to unless you forgot the scotchbrite or have sore fingers...
            (If I remember to do it, I have a few used spare shafts that I will test this theory out and post some microscope picks. And hell, if someone sends me a new shaft [not that I need one] I can put this puppy to bed )
            • copyman
              Owner / Technician
              • Sep 2005
              • 4651
              #21
              Just my preference, emery cloth works best out of everything I've tried.
              What ever is used the most important thing is to "sand" in direction of shaft length not "around" the shaft. You want to rough up shaft so pin bearings inside clutch grab shaft. If you sand "around" the shaft it could actually help bearings to slip.
              • srvctec
                Former KM Senior Tech
                • Oct 2009
                • 827
                #22
                That's exactly the opposite of what we've found. Since the shafts all come from the factory with micro grooves in them from the machining process, we sand around the shaft to put it back to factory like condition. We tried sanding along the shaft with the logic you have but found that it caused a ridiculous amount of jams and when sanding back to like the factory, the issue was solved.
                Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4651
                  #23
                  Sanding along the shaft was what they teach at Konica Minolta factory training school. Appreciate the advice but have to keep doing what has been working for me. Been doing it for many years and never had an issue.
                  • Synaux
                    • Mar 2012
                    • 1224
                    #24
                    Random thought.... Probably a helical pattern (in the right direction) is the most appropriate.
                    • srvctec
                      • Oct 2009
                      • 827
                      #25
                      I'm KonicaMinolta factory trained on a crapload of machines and have never seen it taught that way in class, to sand along the shaft.
                      BTW, I wasn't giving advice but just stating what works for us and has for decades which is the way we'll continue to do it. We don't have to agree, you know.
                      Probably so!
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4651
                        #26
                        Probably so!
                        I agree it's ok not to agree
                        Will keep in mind if way I've been doing it ever doesn't work. Options are always good to have.
                        Only thing techs can do on this forum is post what works for them. Most techs have their way of doing things. So if a few different methods of doing something is posted it's up to the reader to try them and see what works best for them. Either way I think it's a valuable tool for fellow techs!
