c3913 in c6500
  • TEST10
    • Jun 2010
    • 69
    [Error Code] c3913 in c6500
    I erase the error (03 01 off), and you noticed when closing the main door,
    • properly screwed fuser
    • check the connectors on both the chassis and the fuser, everything is normal (cleaner contacts)
    • I do not know what else to do?
  • methogod
    • Dec 2008
    • 921
    look in the back connector any paper? on the machine side? it not seeing the fuser, start at back and work forward. GIve me some history? Did it work until you did a service?
    • Ziggy
      • Feb 2018
      • 789
      try setting sw 3-1 to 1 .
      then if 3-1 changes back to zero after reboot then you will need to look closely at connectors for fuser
      • TEST10
        • Jun 2010
        • 69
        It was after a paper jam.
        sw 3-1 to 1, I also tried it already
