C-3110, not printing...
  • Oystercopy
    • Oct 2009
    • 623
    Hey guys. So, I installed this machine yesterday, although I can't specifically remember if I tested the PRINT functionality. Got it to the customer and on their network, and I can get to Pagescope, the driver loads, etc. but the machine will never print. All test prints and other jobs just stay in the queue. Any ideas? Firmware is also up to date at level D.
    Thanks in advance!
    OC
  • Synthohol
    Certified Konica Expert
    • 5814
    Re: C-3110, not printing...
    make sure its port is 9100 and standard ip, not that WSD bat guano.
    • tsbservice
      Field tech
      • 8001
      Can you ping it?
      • Synthohol
        • 5814
        i think he said he can open pagescope, hope its as simple as a port or authentication issue.
        didnt mention if acct track or autherntication is being used.
          • 23003
          Can you print directly from the laptop, off the network? It could be as simple as a duplicate IP. =^..^=
          • Oystercopy
            • Oct 2009
            • 623
            thanks for all the replies, guys. No, I hadn't tried from a laptop, and it is possible that its an IP address conflict...
            Waiting for the customer's response then will try to post back.
            OC
            • Oystercopy
              • Oct 2009
              • 623
              OK, not an IP address conflict.. anything else?
              OC
              • Synthohol
                • 5814
                is acct track or authentication off?
                any consumables past life?
                try a network initialization yet?
                • Oystercopy
                  • Oct 2009
                  • 623
                  No consumables past life.
                  Machine only has about 2K pages.
                  I didn't know there was a network initialization setting on this small machine?
                  If so, is that in Service Mode somewhere?
                  OC
                  • tsbservice
                    Field tech
                    • 8001
                    Admin settings - Security Settings - Initialize - Restore Network
                      • 23003
                      Were you successfully connecting directly to your laptop? =^..^=
