Bizhub C454e Email scanning
  • Bricorley
    • Jul 2017
    • 42
    Ok' Ive tried everything..
    got a call from my customer that email scanning is not working. They said Comcast went in and changed a bunch of security settings on the router side. I reset the router to factory and checked all my google settings. All is perfect but i still get server connection error. This is what is have done
    - changed email to a new account
    - tried my own email account
    - under details ive pinged 8.8.8.8 / smtp.gmail.com and completed
    - changed router / modem to factory
    - firmware was flashed to G20-K9
    - Ensured Less Secure is active
    Any thoughts?
  • Max
    • Oct 2011
    • 566
    Re: Bizhub C454e Email scanning
    Log in to Google account using customer pc. Confirm it was you when you get security email from Google.
    Check dns ip is correct or use Google's smtp IP address if dns unknown/ not working
    Check ssl/tls are ticked in security settings and sertificate hasn't run out.
    Best to renew it anyway, and delete the old one.
    I find tls is better. Port 587
    To rule out rooter. Connect you laptop to your phone via hotspot and connect copier to you laptop and share the network connection. Google it on how to. If works then something still not quite right on the rooter.
    Good luck.
    • Bricorley
      • Jul 2017
      • 42
      Good luck.
      Ive tried your suggestions on my 1st attempt. Still at a loss of words
      • PrintWhisperer
        • Feb 2018
        • 474
        Aside from 'Hey get a real service for business email' here are some tips from Google:
        Require mail to be transmitted via a secure (TLS) connection - Google Workspace Admin Help Setting Google account for TLS on email
        Send email from a printer, scanner, or app - Google Workspace Admin Help General options for gmail connections.
        STARTTLS for your auth setting when using port 587 btw
        "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
        • Synthohol
          Certified Konica Expert
          • 5892
          G20-k9 is 3 versions behind
          G20-m1 is the latest (lol2016)
