konica minolta bizhub 226 memory clear
  • Yovan
    • Jul 2021
    • 2
    Hello. I use Konica 226, and for some reason the memory was erased. may have been done by the on / off button?
  • GIUBOSS
    • 1433
    Re: konica minolta bizhub 226 memory clear
    What do you mean by memory, factory reset or personal settings? Unlikely cause, to be scrupulous check the switch that has no burns etc otherwise it could be a malfunction of the buffer battery or the controller board.
    • Yovan
      • Jul 2021
      • 2
      I mean memory reset and total clear. If is not a malfunction can I check if someone did the reset?
        • 23007
        If this machine is used/re-sold it is common practice to de-commission the machine erasing customers private date and print logs.
        I have had over-exuberant HP owners accidentally find the "Factory Reset" button, then call me saying that they couldn't print or scan any more. hmmm ... what could it be?
