Hello
This is one of those "has anyone come across this before"... so any pointers and any suggestons most welcome.
C7000, 11M+ clicks (yes high I know), only OEM consumables...
The image below shows a repeating ghostly black mark that appears on anything printed irrespective of image/colour, including no image jobs/blank sheets, test patterns etc.
In the pic, you'll see the top edge of an SRA3 sheet where the direction of print is from left to right and the mark is on the side of the paper towards the rear of the machine
The mark although from a distence looks the same, actually varies in the style of the 'peaks' or ripple effect.
FYI - Black dev and black dev unit replaced back in March and dev is at 66%.
Upon the appearing of the mark I have replaced the black drum unit with new oem drum likewise corona.
The pattern repeats roughly every 186-196mm which is why I replaced the drum unit, but there was no change.
The TB is 145% of life, but visually in good condition.
Relative humidity was higher than usual for us at 45% usually 35% (as measured on the machine), there is basic air conditioning in the room where the machine is housed too which includes humidity control.
Note: there are no codes being thrown by the machine, it will hapily run any job in this condition, indeed I ran the job I needed to 1up SRA4 instead of 2up SRA3....
I have run the tonor desity restore as it had run a long B/W job at the end of last week, only 10% coverage though, as well as the tonor refresh for black.
The one thing I am yet to try is the panic stop and look through the process unit to see where the image is residing, although I am expecting it to appear on the drum. In my mind I am unable to work out how - if it is the write unit - how is it possible to excite the drum in such a way.
Anyway... yes I am an end user, but endevour not to take your expertise for granted and am most grateful for any suggestions, and contribte to this forum when appropriate. We've had KM MFP's and presses for 13 years and all bar the first one have been maintained by ourselves, so not a complete numpty, but happy for someone to prove me wrong there
Mark
Mark
