Konica C220 print quality problem
Re: Konica C220 print quality problem
In your case you had to replace the dev bk too? In addition to the clutchComment
Check to see if the K developer unit is turning, if its packed full of toner clear to the top, its usually a sign its not, and that clutch mentioned is bad. If you run with the cover open, and place your fingers on the k developer, should feel some vibration if the auger is turning.Comment
My Ricoh knowledge is slowly dwindling away at this point. Many things have been lost to time...Comment
