Konica C220 print quality problem
  • ferro10
    • Jun 2015
    • 117
    Hello everybody A customer reports quality problems printing on black. He says that wavy print (see file)
    In My opinion The Problem is the BK Development Group.
    Do you have other ideas?SKMBT_C22021071912031.pdfSKMBT_C22021071912030.pdf
  • Synthohol
    Certified Konica Expert
    • 5868
    Re: Konica C220 print quality problem
    needs a new black DV unit.
    • tsbservice
      Field tech
      • 8031
      K developer unit almost developer empty.
      • mandongo
        • Mar 2021
        • 32
        Black developing unit 100%.
        I had the same issue. After replacing it everything was ok.
        • femaster
          • May 2011
          • 1515
          Just to add yet another +1 for the K dev unit. Make sure K drum isn't over life as well, replace if it is.
          • ferro10
            • Jun 2015
            • 117
            thank you all
            ok then I replace K dev unit
            • avecosat
              • Jun 2012
              • 305
              Also check the clutch of the dev unit K A0EDM20000
              • ferro10
                • Jun 2015
                • 117
                replaced Dev BK now everything works regularly
                thank you all
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4738
                  thank you all
                  Like other poster mentioned replace black drum as well or you will be back there when the developer dumps again from over life drum shorting out.
                  A lot of posts on this forum about "4 series dumping developer
                  • ferro10
                    • Jun 2015
                    • 117
                    For 4-5 days the printer worked regularly.
                    now the same problem has been presented
                    Now I try to change only the drum bk? or I have to change the dev bk again together with the drum?
                    PS: Can it be a toner hopper problem that does not download toner inside the dev bk?
                    • femaster
                      • May 2011
                      • 1515
                      You will need to do both, including K dev unit. Replacing just the K drum won't get your developer back, which is now sitting in your waste toner box, along with the developer from the last dev unit.
                      • avecosat
                        • Jun 2012
                        • 305
                        Is the clutch ,I have had the same problem a couple of times
                        • ferro10
                          • Jun 2015
                          • 117
                          What clutch are you talking about?
                          • Zesti
                            • Jun 2009
                            • 308
                            Which toner are you using? sometimes bad toner also causes developer going in waste. How did you change dv only unit comes as whole... with drum.
                            • ferro10
                              • Jun 2015
                              • 117
                              The black toner is original
