bh958 2002 jams
  • Hap
    • Jan 2017
    • 33
    bh958 2002 jams
    anyone seen this seems very intermittant at times stops just before reg rollers
  • copier tech
    • 8141
    If the paper hasn't reached the reg sensor replace all the feed rollers & clutches. Or the complete feed unit. If the device has a high count the reg sensor arm can wear down causing the same issue.
    • piksel1983
      • Oct 2018
      • 38
      Change the one way bearing in drive unit.
      • Hap
        • Jan 2017
        • 33
        not sure which one way u are talking about
