konica and ineo
  • rrrohan
    • Sep 2011
    • 1977
    konica and ineo
    Just inherited a punch of customers with ineo copiers
    so far the drums from the compatible konica work ok.
    curious about software switches and toners.
    am yet to try but the fact drums worked is a good sign. Is the only difference the firmware?
  • copier tech
    • 8138
    Re: konica and ineo
    Everything is identical inc the firmware.
    If you change SW 10 to HEX 02 this will change it to a Konica Minolta then you could change the front cover logos.
    • L0rdC
      • Feb 2021
      • 82
      Re: konica and ineo
      I have tried on an ineo 654e and it was in 02 by default, and it is still develop
      • copier tech
        • 8138
        Re: konica and ineo
        Maybe try HEX 00
        • Synthohol
          Certified Konica Expert
          • 5814
          Re: konica and ineo
          print a network config sheet, see if it says generic or an actual model.
          if generic you may need to set the Machine and Type correctly from a FW boot stick.
          • tsbservice
            Field tech
            • 8003
            Re: konica and ineo
            Why so much buzz about being KM or Develop? My Develop machines are perfectly running with KM firmware and consumables. I'm talking about 8 series and newer though.
            So what fleet we are talking about?
            • rrrohan
              • Sep 2011
              • 1977
              Re: konica and ineo
              im surprised develop still exist. didnt ricoh shut down there re badge brands? i dont really see the point in rebranding
              • Blizzoo
                • Aug 2013
                • 608
                Re: konica and ineo
                Analog machines still exist and do copies
                • robinsonad86
                  • Aug 2014
                  • 67
                  Re: konica and ineo
                  Develop are going strong in the UK. Olivetti have pulled out of the region and KM and Develop have swooped all over the partner accounts they left behind
                  • rrrohan
                    • Sep 2011
                    • 1977
                    Re: konica and ineo
                    the only downside ive heard is they are always 1 generation behind, is that true
                    • robinsonad86
                      • Aug 2014
                      • 67
                      Re: konica and ineo
                      No atleast not over here i series machines available from both KM and Develop
                      • tsbservice
                        Field tech
                        • 8003
                        Re: konica and ineo
                        Same here. They may cut some extra super-duper options from Develop price list that seems the only difference. I have both brands same models working side by side both running strong.
