how to run the motors, fans, and solenoids on the Konica Minolta C558.
  • Harry-printer
    • May 2024
    • 2
    I would like to know how to run the motors, fans, and solenoids on the Konica Minolta C558. Could you please help me with instructions on how to run each of them separately?
  • Albonline
    • Sep 2008
    • 1153
    get a manual look up load check mode. used to be called i/o mode
    • Synthohol
      Certified Konica Expert
      • 5888
      load checkc558.pdf
      service mode, state confirmation, load check
      • Reed
        • Feb 2011
        • 258
        As stated by Synthohol it's under load check, but its not that straight forward without the manual. There are a couple procedural things you need to do. Also manual will help you find the correct test modes
