C308 airprint tab missing
  • Massimiliano
    • Oct 2019
    • 48
    Good morning,
    I have a c308 where you can't enable Airprint in the network settings.
    I usually find it without problems, do you know if there is a software switch that activates the function?
    Thanks and good job
  • rrrohan
    • Sep 2011
    • 1977
    check under admin - security - quick security and check airprint isnt toggled off
    • Thib
      • May 2017
      • 35
      Softswitch 25 to hex 60
      • Duplicator
        • May 2022
        • 252
        What firmware and function version are you on? Apple changed things with iOS 17 and Airprint will have issues if the copier isn't updated enough.
        Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
        If I helped you out, please give me a thumbs up! It helps my reputation.
        • Massimiliano
          • Oct 2019
          • 48
          Thanks but it doesn't work,
          I set Softswitch 25 to hex B0 (firmware A7PU0Y0-F000-GC3-W4)
          On the other machines everything works, on this one it is not possible to enable it.
          Thank you
          • Synthohol
            Certified Konica Expert
            • 5871
            wasnt there a bulletin about a license code that needed to be updated/entered to enable airprint on some models?
            • JMS
              • Apr 2023
              • 30
              That wos an i-series some firmware ago
              • Synthohol
                • 5871
                thanks, sorry, havent touched a copier in 22 months.
                • strider5555
                  • Jun 2008
                  • 96
                  Here are some instructions for enabling airprint on various 7,8 and 9 series MFP's. Also make sure Bonjour is enabled otherwise airprint won't show up Activation code for authorization function-.pdf Activation_of_authorization_function.pdf
                  • Massimiliano
                    • Oct 2019
                    • 48
                    Originally posted by strider5555
                    Here are some instructions for enabling airprint on various 7,8 and 9 series MFP's. Also make sure Bonjour is enabled otherwise airprint won't show up [ATTACH]n1569949[/ATTACH] [ATTACH]n1569950[/ATTACH]
                    thank you so much!!!
                    I'll try your info on Monday and update you.
                    have a nice weekend
                    • Massimiliano
                      • Oct 2019
                      • 48
                      Good morning, I tried to activate the code on both a c308 and a 308.
                      it always gives me this error: Function code verification failed.
                      Am I doing something wrong?
                      Thank you
                      • Synthohol
                        • 5871
                        is the machine plugged into the internet?
                        • Massimiliano
                          • Oct 2019
                          • 48
                          Yes, should it be done offline?
                          • Synthohol
                            • 5871
                            ive always installed licenses with the machine online.
                            • Massimiliano
                              • Oct 2019
                              • 48
                              I have tried several times on copiers that airprint is not active but the result is always negative.
                              Any other suggestions for solving this?
                              Thank you all
