What seems to be hard toner top of page
  • positiveg
    • Jun 2018
    • 299
    All, hoping everyone is well.
    Please check out the photo attached and let me know please what could be causing this.
    We getting this hard toner at least that's what it feels like running top of jobs on 11*17 prints bit happens on both sides. I had a toner in there that head seemed to have malfunctioned so I switched it black toner. But same issue seems to to still be taking place. Could it be leakage from the toner or summen else?
    Sent from my SM-G955F using Tapatalk
    • 15011
    Re: What seems to be hard toner top of page
    Not knowing what machine makes it difficult to give an accurate answer, but I would say by the picture you have a failing black dev unit.
      • 23010
      Let's start with the simple questions:
      What model is this?
      Is that pattern appearing in the feed direction or crossfeed direction?
      Why aren't there any image voids?
        • 16521
        The total and PM counters would be helpful.
        • positiveg
          • Jun 2018
          • 299
          Sorry for my bad banners folks
          The machine is a C454e
          The dev unit was recently changed earlier this year
          And we haven't been doing a lot of prints over past months because of lockdowns etc
          It eventually stopped and I think could of been because of the fact the black toner the cap was loose so it seems like more toner may have been spilling into the bin that was necessary
          I'll let you guys know if it comes back today
          something similar though started happening with the Cyan blue streaks top of the 12 x 18 paper only.
          • robinsonad86
            • Aug 2014
            • 67
            Drum and transfer belt lives? Also are the filters clean or backed up with toner?
            • emujo2
              • Mar 2017
              • 1579
              if you can feel it, it's probably developer. E
              • positiveg
                • Jun 2018
                • 299
                yeah i can feel it
                I think i have the developers in stock because last time that happened it hurt me for a week or so waiting for them to get here.
                So should have that in stock
                But why does it empty so fast
                My Xerox C75 changes maybe once every 18 months this is almost liek every 8
                and we use the Xerox more for lot larger quantity jobs.
                • positiveg
                  • Jun 2018
                  • 299
                  Drum lives above 80 all of them
                  transfer belt 67
                  Fuser 87
                  Toner all mainly full and genuine.
                  the last black as I said was leaking
                  And I'm seeing it top of page the cyan I'll try get the team send me a photo so can forward to you guys to take a look at.
                  • kingarthur
                    • 1390
                    Blocked toner filtration system can cause the problem, over life or Faulty Consumables can cause it
                    as well as replacing DV & Drum of the faulty colours, lower the TCR value of the affected colour by "-1" if it reoccurs then lower it again. Check the MC grid on the drum unit of the failed colour, is it covered in toner one end/both ends
                    As well as checking the filters, remove the main drive, and vac out the ducts on the main drive
                    Any over life consumables, can cause other colours to fail, so make sure that everything is within life
                    • tech_in_greybruce1
                      • Jan 2021
                      • 8
                      Check for build up on the fuser roller
                      • positiveg
                        • Jun 2018
                        • 299
                        Thanks all. Will check out the filters and for any build up
                        Sent from my SM-A025M using Tapatalk
                        • Brett GS
                          • Jun 2013
                          • 154
                          Check the black drum.
                          More then likely the charge unit has toner in it.
                          • positiveg
                            • Jun 2018
                            • 299
                            Will check this too.
                            • tulintron
                              • Jul 2014
                              • 668
                              Why doesn't the cyan image have white borders?
