parts No.
  • romario
    • Jun 2020
    • 193
    parts No.
    Hi Friends. Can you help me with parts No of gear developer unit km c558. thanks
    thanks
  • Zesti
    • Jun 2009
    • 309
    Check Aliexpress. As OEM does not provide these gears separately. Nice pic though.
    • tsbservice
      Field tech
      • 8052
      Just a thought but K ones are usually cheap.
      • rrrohan
        • Sep 2011
        • 1977
        if you post in here https://www.copytechnet.com/forum/te...the-parts-room you might be able to get someone to send you a old used dev that is faulty as im sure the gear would still be ok
        • copyman
          Owner / Technician
          • Sep 2005
          • 4764
          There are no #'s for developer parts because they are sold as complete units. Why not just use gears from another DV unit? or like tsb posted black DV units aren't that expensive compared to the color units. Would also be concerned why the gears wore out and same will happen to new gears. Personally I would replace whole unit. If you insist on replacing the gears there is an aftermarket dev gear set sold by CET. Around $4.00
          • rrrohan
            • Sep 2011
            • 1977
            i have worked on km for ever 10 years and never had dev gears fail
            • Toxic
              • 698
              Exactly, i had that situation only once but complete unit was blocked with caked replacement toner and only new developing unit is good solution.
              K is cheap, not worth bodering to replacing gears and maybe problem again in near future.
              • Tech09
                • Apr 2020
                • 147
                If the drive input gear on the black developer unit is worn, you will have to look at it's corresponding gear in the main drive unit also. Pull the black drum and developer units, open the side door and remove the fuser (that's just for convenience) and look down at the gear, I usually use my cellphone and take a picture with the flash on so I can see it better. This gear wears out and the only way to replace it is to order a whole main drive assembly UNLESS you just happen to have another machine you can pull that drive out of and swap your black gear with any of the color gears on the loaner drive. It won't do you any good to fix or replace your black developer unit if that drive gear is worn also.
