Konica 364E serial number must be entered
  • ferro10
    • Jun 2015
    • 117
    [Error Code] Konica 364E serial number must be entered
    Hi everyone
    A few user to ever see this error? Serial Number Must Be Entered (see attached photo)
    How did you solve?
    Thank you
  • tsbservice
    Field tech
    • 8019
    NVRAM battery is dead. You should resolder another in parallel and cut leg of old one eventually.
    Counters may have lost and other settings depending on your luck.
    • ferro10
      • Jun 2015
      • 117
      After replacing the battery, do I have to do some particular procedure?
      • copyman
        Owner / Technician
        • Sep 2005
        • 4712
        Probably have to enter serial # in service mode. Wont be able to put meter counts back in. There have been a few times where I had to go through "complete" setup procedure after replacing battery.
        • ferro10
          • Jun 2015
          • 117
          Thank you
          What would be the complete procedure?
          • copyman
            Owner / Technician
            • Sep 2005
            • 4712
            The complete procedure is like the machine is new out of the box. The setup procedure is in the installation info (PM me if you need it). Would also update firmware.
            • SAR
              • Jul 2009
              • 203
              This is the best procedure I've seen to fix that problem. I can't find that post on here, so i'm going to post a picture.
              Hope this helps.
              This gallery has 1 photos.
              • ferro10
                • Jun 2015
                • 117
                Hope this helps.
                Thanks for the reply
                In my case the reset tool was not necessary.
                After replacement of the battery I made the reconfiguration with date, HDD installed, ADF setting and Fax Settings everything works regulatory.
                Obviously the printer's counters have reset to 0
