BH-363, service code C3421. Which ICP might be blown?
  • Hansoon
    • Sep 2007
    • 3374
    BH-363 has a service code C3421 after a short between 24VDC and ground ( don't ask me how I know..., please........., ). I think an ICP on the power unit has been blown. Anyone has a list of the ICP's of the BH363/423 or know at least where to find the responsible ICP, please?
    Hans
  • Synthohol
    Certified Konica Expert
    • 5799
    check those voltages because the manual i have does not show any ICP for fuser related codes that i could find but just to ask have you done a trouble reset because its a fuser middle lamp code. it wont clear by rebooting or even a new fuser.
    oh, and i have seen fuser codes that share the same ICP as one of the DV units and we had a bad DV we found after replacing the fuser 3 times and the prcb 2.
    • Hansoon
      • Sep 2007
      • 3374
      Machine was working fine until Hans came and f$cked it up by rerouting the vendor unit wiring while MFP was under power. ? ?
      Immediately after that, the service code C3421 popped up and 24VDC was lost. Trouble reset didn't help of course.
      Hans
      • Synthohol
        • 5799
        oh my.
        fwiw the ICP should be somewhere close to the cn16 connector. just ohm out a bunch and see if you find an open on otherwise its PRCB time.
        have you checked all the fuses on the power supply?
        • Hansoon
          • Sep 2007
          • 3374
          Not yet, will do tomorrow. Now I am too damned tired because I have a serious health issue to fight with too.
          Thanks for your help, Pal.
          Hans
          • Tech09
            • Apr 2020
            • 144
            Hans
            lol I think anyone who's been doing this job for a while has done similar things. I may have had a few experiences like this, forget to plug in a ribbon cable see a bright flash, little bit of smoke and really nice scorch marks lol
