Konica Minolta C308 fuser unit termostat
  • christian8220
    • Jul 2020
    • 53
    Thank you in advance
    This gallery has 7 photos.
  • Synthohol
    Certified Konica Expert
    • 5905
    therm.jpg black sticker is normal. just clean the burned toner off it with IPA and a q-tip
    fwiw this one is out of a scrap c454 fuser. its the same 152#
    steal one from an old scrap fuser or just clean yours
    ROFL, just remembered its a thermal SWITCH cutoff, if you push it, the bi-metal pops and stops the flow of AC to the lamps.
    if you smack it on the table button side down it will likely reset and let the voltage through.
    i used to pop reset those things daily when i worked on kyoceras.
    see video above
    good luck!
    • christian8220
      • Jul 2020
      • 53
      Does the error message C39250 need to be reset first? Or could it be a faulty sensor or the heat lamp that is broke. The hole thing was working before I took it apart.
      • Synthohol
        • 5905
        you must perform a trouble reset after any fuser or lamp code.
        do that and reboot.
        • christian8220
          • Jul 2020
          • 53
          Thank you for your help. It fixed the problem. Sorry for the late response
