C-FA14 BH458e
  • Tiagocang
    • Feb 2022
    • 62
    C-FA14 BH458e
    Good morning, I hope everyone is well.
    I have a problem if someone could help i will aprecciate, so I have a BH458e at a client and it presented error C-FA14.
    I have already done the following procedures:
    • Update Firmware
    • Format HDD
    and the code still appear
    the following detail code is 0x0767.
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5840
    ive seen the wrong driver/port print job do that as well.
    have you tried isolating it with a laptop and printing?
    in state confirmation check the HDD status, should be a big chunk of "vacant" listed. if not its a bad hdd.
    reseat any ram on the board too.
    does it do it only when printing or pops up at idle?
    • tsbservice
      Field tech
      • 8019
      Maybe it's good idea if they can use machine as copier for a day or two and you can unplug network cable.
      Another idea is to backup everything and initialize all.
      • Tiagocang
        • Feb 2022
        • 62
        the machine is unplugged from network only working as a copier now for testing and still pop up the error
        • Synthohol
          • Mar 2016
          • 5840
          absolutely at this point.
          dont forget to reenable the HDD after initialization.
          let us know
          have you run diagnostics by chance?
          sorry, i still have a million questions because im not there to go over my mental checklists at the machine.
          • Tiagocang
            • Feb 2022
            • 62
            let us know
            HDD is enable and diagnostics run all ok i literally have no more ideas for this ?
            WhatsApp Image 2024-07-05 at 10.15.43 (1).jpg WhatsApp Image 2024-07-05 at 10.15.43.jpg
            • Rudi
              • Jun 2007
              • 251
              Try replacing the eMMC, i had this error code on the C558 a couple of times before and this solved it.
