Konica Minolta C3350i line on scan
  • DiVallelunga_Makhymo
    • May 2017
    • 10
    Hi, we have this konica minolta c3350i that by making scans or photocopies only from Adf creates these lines. Practically it eats away the written parts. Has this already happened to you? I state that I have not yet tried to change anything.
    Thank you.SKM_C3350i21080610160.pdf
  • suomi
    • Oct 2008
    • 152
    • minoltaed
      • Aug 2009
      • 44
      Re: Konica Minolta C3350i line on scan
      Any fix for this yet?
      • tsbservice
        Field tech
        • 8001
        Apart from cleaning slit glass
          • 23002
          Not this time, tsb. If you look closely on the samples the image is compressed crossfeed. I can be sure since an A4 machine cannot scan the other way.
          • tsbservice
            Field tech
            • 8001
            Lol now I definitely know I need to put on some glasses. I also must quit using my phone instead of desktop. My bad, however interesting compression through the ADF. Looks like an image processing error nothing mechanical.
              • 23002
              I agree. The grounding issue mentioned above might be it. On the Canon faxes we used the black conductive grease on those grounds. =^..^=
              • tsbservice
                Field tech
                • 8001
                Black conductive grease we used on Toshiba estudio 350/450 drum shafts should be the same. Even on Konica drums it's used i.e. C224e.
                • suomi
                  • Oct 2008
                  • 152
                  Originally posted by suomi
                  A bad grounding from the “Pick-up-Roller” / “Document feed roller” section to the main body of the ADF
                  Knowledge Article: Version:
                  RFEU_BT2111268EN
                  Clean the axis and the bushing; the bushing on the inside and the outside.
                  The bushing is responsible for a good contact.
                  Clean the grounding spring.
                  Check for the correct position of the ground spring wire.
