Bizhub c368 wont eneble web browser
  • ralleyman
    • Dec 2019
    • 5
    i have 2 machines that i am putting Papercut on the issue i have is i cannot enable the web browser on both machines, they ask for the licence code and when you create a licence on the lms site it just says failed when adding the licence to the machines. any ideas please
  • Albonline
    • Sep 2008
    • 1147
    Re: Bizhub c368 wont eneble web browser
    are they both equipped with the memory upgrade?
    • Synthohol
      Certified Konica Expert
      • 5814
      why wont it enable by itself in admin mode?
      as long as DNS and gateway are valid you dont need the LMS site.
      • tulintron
        • Jul 2014
        • 668
        We are an unauthorized reseller, however we sell with PSWC enabled.
        We recently released 02 C368 without web browser access. We tried everything, but without success.
        Different situation.
        • emujo2
          • Mar 2017
          • 1579
          For self activating the license..DNS must be working, device must be able to get to the LMS server (which is not in north america), WebDav cannot be blocked/disabled, UK 211 must be installed (this was standard with the C368 series, but many sales people failed to add it to the order). If you do not have internet access then you would need to go through the LMS/activate site, but even this way still requires Webdav and the UK. In one case we had to delete all certs, disable SSL, perform a initialization, then start from scratch. E
          • tsbservice
            Field tech
            • 8003
            [Utility] - [Administrator Settings] - [Network Settings] - [HTTP Server Settings] - [PSWC Settings] is set to [ON] ?
            [Utility] - [Administrator Settings] - [Security Settings] - [Quick Security Setting] - [PSWC Setting] is set to [ON] ?
            • tulintron
              • Jul 2014
              • 668
              yes.
              We have our default configuration. All the same. FW, adjustments and functions.
              Only 02 without PSWC
              • Synthohol
                • 5814
                if it were me i would do a total data clear, fresh G00-X4 FW and start over.
                if indeed the UK-211? has been installed it really should work right from the admin method.
                • Albonline
                  • Sep 2008
                  • 1147
                  i have only seen units that have had the boards messed with, act in this manner. are the required serial numbers registered?
