Pagescope data administrator and account track, 8 series
  • copytechman
    • Nov 2008
    • 969
    I've run into an issue data admin not working on 8 series (multiple models) if they are upgraded past the w8 firmware (iirc). I haven't had the time to hunt down through a Jillion special firmwares across multiple models. Any thoughts? Also on w8 using account track data admin doesn't work proper with the device if you delete codes in the middle. You'll start to get duplicate code errors when downloading (but the device itself shows proper). Any thoughts from you knowledgeable bunch?
    Regards!
    A!
  • tsbservice
    Field tech
    • 8081
    Re: Pagescope data administrator and account track, 8 series
    Are you using latest version of PSDA - 4.1.48000?
    • emujo2
      • Mar 2017
      • 1579
      Agree, the main reason PSDA wont connect is it's not updated. New firmware should not be a problem unless you have failed to match the function version softswitch. E
      • copytechman
        • Nov 2008
        • 969
        Yes, unless there's a newer version now.
        Regards. A.
        • copytechman
          • Nov 2008
          • 969
          I don't mess with the function version on the device unless there's a problem, and these were 2 different devices. Should the 8 series always be set to the highest function version? I haven't run into that otherwise.
          Regards!
          A.
          • Synthohol
            Certified Konica Expert
            • 5922
            Originally posted by copytechman
            IShould the 8 series always be set to the highest function version?
            yes. B0 i believe.
            • copytechman
              • Nov 2008
              • 969
              Originally posted by Synthohol
              yes. B0 i believe.
              Good to know, I'll give that a go next time I have to cross paths with pagescope again!
              Kind regardsA.
              • Synthohol
                • 5922
                the website layout with the new version im not a big fan of but it looks more mature than the pastel kindergarten one we have seen for over a decade.
                • copytechman
                  • Nov 2008
                  • 969
                  LOL! I hear ya!
                  A.
                  • tsbservice
                    Field tech
                    • 8081
                    Regards!
                    A.
                    Should be 4.2 function version. B0 as Synt mentioned. Strange things may happen when firmware is updated without matching switch 25.
                    Good luck
                    • copytechman
                      • Nov 2008
                      • 969
                      Good luck
                      Duly noted, thanks kindly, thus far the only anomaly i have seen is the inability of pagescope data admin to work with the latest firmware of the device, nothing more. Aside from the account track issue on the older firmware that is (which is hard to say if device or data admin)
                      Thx so much
                      A.
                      • srvctec
                        Former KM Senior Tech
                        • Oct 2009
                        • 827
                        Just another thing to add in case some aren't aware; after updating F/W and then changing SW25 to the appropriate value notated in the accompanying pdf, make sure to power down the machine with the main power switch. If you don't the SW25 change doesn't take hold and you'll have the aforementioned issues of not changing SW25 in the first place. That one bit me hard once and I've never forgotten it.
                        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                        • tsbservice
                          Field tech
                          • 8081
                          I'm relatively freshman regarding Konicas but I learned from the start to never change anything in service mode without cold reboot(from the power switch). Doesn't matter it's needed or not(as per manual) my rule of thumb is - reboot is always good
                          • strider5555
                            • Jun 2008
                            • 96
                            Had this same issue with 8 series and B227/287. After updating beyond W5 firmware always got failed to import error on data administrator. Sw 25 was set correctly, latest version of PSDA. What I ended up doing was a data clear and restoring the machine to factory, then setting it up from scratch. Not so very convenient if it is on a customer site. KM released a KB article about this, to set SW 172 to Hex 01. This fixed the issue for me when I couldn't do a data clear in the field.
                            Failed To Import PSDA.pdf
                            • copytechman
                              • Nov 2008
                              • 969
                              [ATTACH]49962[/ATTACH]
