C-450i, CD-313 code...
  • Oystercopy
    • Oct 2009
    • 623
    I looked for related posts on this code on this forum, and all I found were the C-3350i series having this code, nothing on the higher speed machines that i could find. According to the manual, I replaced the TMPB board and this did nothing. The screen offers to "recover data", but that yields nothing either and the machine simply reboots back to the original CD-313 code. I have not replaced any of the other boards yet (this machine has about 650K and may not be worth going further), but I wondered if you guys had been successful doing anything else to remedy this code? The customer traded the machine in to me, and they believed they had a power event at the building prior to the machine doing this, without any surge protection.
    Any help appreciated!
    OC
  • occus
    • 337
    I had this 3 times on +250i, always cpub
    • tsbservice
      Field tech
      • 8019
      Before replacing CPU board as a last resort I would try enter service mode via trouble reset and perform
      Backup manually with the following setting. [Service Mode] -> [Enhanced Security] -> [Memory Data Backup]
      • Oystercopy
        • Oct 2009
        • 623
        Thanks guys.. well Konica support had me try a late model FW, which the machine didn't take, so now its stuck at the "invalid external memory". .... I tried to reload the original FW the machine was at, and it won't take it anymore, so now its stuck at this... ARRGGHH..
        OC
        • copytechtrouble
          • Nov 2020
          • 109
          Replace the CPUB. that error is always the CPUB on the i series.
          • Oystercopy
            • Oct 2009
            • 623
            OK, so I got ahold of and used the Recovery Tool, and it does indeed say "replace CPU" so that's something I'll do if it's cost-effective.
            Thanks again people.
            OC
