the front and back are not activated
  • Daniele
    • Jun 2019
    • 15
    Hi guys, I have a Konica Minolta C224, when I try to do the front and back the print comes out directly as if I hadn't selected the front and back, once the sheet comes out it also jams.
    I thank you in advance.​
  • Thib
    • May 2017
    • 35
    Either the gate solenoid is bad on the paper exit or (even easier) look at where the gate arms rest on the door. They have pads to quiet it on actuation. Over time, these pads become sticky. Peel, clean, replace with a piece of velcro.
    • Tiagocang
      • Feb 2022
      • 62
      spring above gate solenoid take it out, give strenght to the spring and thats it, solve like 50+ like that
      • Daniele
        • Jun 2019
        • 15
        Grazie, vi aggiorno.
        • Tech09
          • Apr 2020
          • 147
          The first time I came across those pads causing the jam took me forever to figure it out. Now one of the first things I do is just remove it, it's usually the rear side one.
          • Daniele
            • Jun 2019
            • 15
            The problem was in the solenoid, obviously it couldn't have been the simplest oneπŸ˜…..... That is, the rubbers but I removed those for safety..Thanks for your help. A good evening.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4764
              I also always remove those pads. But I don't put anything in their place just clean residue off with alcohol and that's it. More often the solenoid and / or spring are issue which has been discussed with fixes many times on this forum. Also there is a bulletin about new style solenoid.
              • tsbservice
                Field tech
                • 8052
                100% correct. Same as I do.
