bizhub C226 C6756
  • jwai
    • May 2018
    • 508
    bizhub C226 C6756
    Hello,
    Do anyone have this issue below:
    One C226 often showed C6756, first time I tried flat cable but still the same, and fixed by replaced CIS module.
    After 4 months the machine showed again, and replaced CIS again.
    After 4 months again, today, it display the same code again......
    What will cause this happen?
  • copier tech
    • 8142
    Re: bizhub C226 C6756
    Originally posted by jwai
    Hello,
    Could be a firmware bug, what version is it on?
    • jwai
      • May 2018
      • 508
      Now it's using G00-11
        • 23006
        On the Kyocera Saturn series the second side CIS failures were caused by a cooling fan failure, and subsequent overheating. On the Saturn series it was SOP to change the CIS and fan in the same procedure. Maybe this applies? =^..^=
        • jwai
          • May 2018
          • 508
          On bizhub C226, it seems not equipped with fan motor on scanner section.
          • tsbservice
            Field tech
            • 8006
            Update firmware.
            • jwai
              • May 2018
              • 508
              I updated the F/W to G00-14, still same, finally fixed it by replaced CIS again.
              This is the third time, no idea what would cause CIS damaged......
