How to disable the scanner in konica minolta c6501
  • vijaysharma
    • Sep 2008
    • 61
    [Misc] How to disable the scanner in konica minolta c6501
    Hi,
    I want to disable the scanner in c6501 can any one able to suggest which dip sw solve this issue.
    thanks in advance
  • Synthohol
    Certified Konica Expert
    • 5824
    Re: How to disable the scanner in konica minolta c6501
    take a hammer to the lamp
    • copyman
      Owner / Technician
      • Sep 2005
      • 4700
      Not familiar with that model but most Kon/Min have "isolation" tab in service mode under system 1 or system 2. "UNset" what ever you want to disable.
        • 30216
        You should be able to remove the scan icon from the control panel.
        If you don't want walk up copies turn on account codes.
        • vijaysharma
          • Sep 2008
          • 61
          This is Production category machine, Therefore, this machine does not have isolation mode, instead it can be turned on or off with a software switch.
          thanks for reply
