B287 scanning barcodes smb/Email
  • blinxwap
    • Jun 2020
    • 80
    Hi guys i have a problem with a b287 scanning a document containing a barcode scanning smb thru document feeder and from platen glas it does the same , the client says a week ago their drag and drop program on their system accepted the codes until recently the scanned document barcodes is distorted see attached images the barcode lines are not accurate, i have also tested scanning the same documents from different machines and it does the same i tested it on a c558 & B454e, on the b287 i have done gradation cleaned mirrors slit glass platen glass firmware is on w4 i will update to Y0 on my next visit ,Adjusted scanniging settings density etc,would font management utility help , any suggestions wpuld be appreciated thanx [emoji106] IMG-20210823-WA0000.jpgIMG-20210823-WA0003.jpg
    Sent from my SM-A725F using Tapatalk
    • 23007
    Re: B287 scanning barcodes smb/Email
    Have you tried scanning the barcode rotated 90 degrees, at 600dpi, monochrome, Text original type? You'll want the bars oriented crossfeed/main scan for the best image resolution.
    The issue I was addressing was barcodes scanned at multiple other locations on multiple other scanners, sent as email attachments, printed, then attempted to be scanned by a reader. It's probably the printers fault, not anything to do with the scan quality ... well yes, it did have a lot to do with the scan quality. =^..^=
      • 8195
      Originally posted by blinxwap
      Hi guys i have a problem with a b287 scanning a document containing a barcode scanning smb thru document feeder and from platen glas it does the same , the client says a week ago their drag and drop program on their system accepted the codes until recently the scanned document barcodes is distorted see attached images the barcode lines are not accurate, i have also tested scanning the same documents from different machines and it does the same i tested it on a c558 & B454e, on the b287 i have done gradation cleaned mirrors slit glass platen glass firmware is on w4 i will update to Y0 on my next visit ,Adjusted scanniging settings density etc,would font management utility help , any suggestions wpuld be appreciated thanx [emoji106] [ATTACH]50001[/ATTACH][ATTACH]50002[/ATTACH][ATTACH]50004[/ATTACH]
      You should acquire a handheld BarCode scanner and check that the printed image matches the barcode data.
      Simply open any word processor and scan the image.
      The image you presented is a combination of machine readable and human readable text.
      The machine readable images are irregular and not fully formed.
      • emujo2
        • Mar 2017
        • 1579
        are there any samples that show a significant change from one day to the next? has the optics been cleaned and the image quality adjustments performed? Are they scanning these in PDF, TIFF? B&W, greyscale or Auto color? What is the resolution (DPI)? E
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          While the sample is far from perfect, it's not all that bad.
          I made a screenshot of it, and dropped it into a free online barcode reader. No issues, including the decimal point.
          You may want to try doing the same thing. There are tons of sites you can do that on.
          • tsbservice
            Field tech
            • 8010
            I think you did a great job. The question is why it worked before and now won't. Can you retrieve from them samples when it worked? Any recent updates made on their program?
            • blinxwap
              • Jun 2020
              • 80
              Could be updates from the program they are using i will try that thanks
              • blinxwap
                • Jun 2020
                • 80
                Thanx will try doing that
                  • 8195
                  I saved the JPEG file to my PC and printed it. I then used my handheld scanner to read it. The BarCode is legible and correct.
                  • blinxwap
                    • Jun 2020
                    • 80
                    These are the original scanned and printed images from the B287 see attached pdf could you try scanning those for me would appreciate itA7AH021002729 - 000012352903.pdf
                      • 8195
                      ... the problem might be with the customers software.
                      You can buy a cheap USB cable scanner on Amazon for $30.00 to prove in front of the customer that the barcodes are legible.
                      • blinxwap
                        • Jun 2020
                        • 80
                        I think i have solved this issue scanning the document 300x300dpi greyscale as a tiff file see atteched converted tiff to pdf as a tiff file it doesnt grey out lines letters or digits
                        Dropbox - tiff before dipsw greyscale(1).pdf - Simplify your life
