bizhub c3350i wakes up randomly
  • Guccs
    • Jul 2021
    • 6
    [Misc] bizhub c3350i wakes up randomly
    Hi Everyone,
    I have a bizhub C3350i that wakes up randomly. Whether it's in sleep mode or standby it wakes itself up after a few minutes. I unplugged the network cable, updated firmware, made system error clear, format storage, but no solution...
    Maybe the touchscreen needs some more grounding..?
    Does anyone have experience with this?
  • tsbservice
    Field tech
    • 8009
    Try to stop machine waking up when someone is close, there is sensitivity setting somewhere in Admin menu but can't remember where of the top of my head.
    • Guccs
      • Jul 2021
      • 6
      Thanks, but...
      That was the first i tried. I was adjusted the sensitivity to the lowest... Nothing changed
      • tsbservice
        Field tech
        • 8009
        Try to disable it not lowest sensitivity.
        • Guccs
          • Jul 2021
          • 6
          Ahh... It is disabled now.
          But I'd like to know the solution, not the way around it.
          I've been a technician for 24 years, now I've run about 300 machines, most of them leased.
          I'am not konica minolta dealer, but one of my friends who is dealer said he saw a buletin for this problem, just can't find it anymore...
          • copyman
            Owner / Technician
            • Sep 2005
            • 4685
            I checked solutions & bulletins on kon/min dealer website and didn't see anything about machine waking up randomly
            • tsbservice
              Field tech
              • 8009
              I believe he's taking about ground cable on some earlier machines.
              • Black Cloud
                • 161
                If there are a series of 0x1FFF/0x2201900000000100 codes in the Machine Management List, it could be the CPU Board.
                The symptom is a random reboot. You would also see the boot progress bar during the reboot.
                Net+ PDI+ @Remote
                • mascan42
                  • Oct 2008
                  • 484
                  He might be talking about this . It's an internal grounding issue in the touch panel. No real fix aside from replacing it.
                  • tsbservice
                    Field tech
                    • 8009
                    Yes. On machines before that there is a workaround with ground wire.
