C224e Date/Time Stuck
  • Salix
    • Jun 2015
    • 3
    Hi everyone,
    Had a customer complaining that their scanned documents were overwriting the previous scans in the folder. Turned out that the time was flicking back and forth between the same two minutes. Yep, the time went in reverse, then forward again a minute later. My first thought was to reflash the firmware, but this failed and resulted in the machine no longer booting up. I had to replace the SSD in the end, after trying an MFP reset which made no difference.
    All seemed good but a few weeks later I noticed the date and time was incorrect again. I immediately performed a manual sync to the google time servers and the same fault occurred. Stuck back and forth between the same two minutes.
    Any ideas?
  • emujo2
    • Mar 2017
    • 1579
    Re: C224e Date/Time Stuck
    Sounds like it could be a weak battery backup..We have been having many issues with the e series related to this..And getting a new board to replace it is almost impossible. I have heard of some techs with good solder skills able to replace battery.
    • tech51
      • 846
      • emujo2
        • Mar 2017
        • 1579
        Can you give me the firmware version for this?
        • tulintron
          • Jul 2014
          • 668
          Just like Emujo said.
          We have already replaced some batteries on the MFPB board. Great result. Perform correct MFPB replacement procedure after installation and upgrade.
          • tsbservice
            Field tech
            • 8028
            I use GXM-M1
            • emujo2
              • Mar 2017
              • 1579
              There is no f/w listed (at least on the US site) with GXM-M1. Special or otherwise. E
              • tsbservice
                Field tech
                • 8028
                Ed, I have no access to my work resources atm but used our PrintFleet to pull this info from one C224e.
                Can do double check later. BR
                • tech51
                  • 846
                  • copier tech
                    • 8182
                    Originally posted by Salix
                    Hi everyone,
                    Any ideas?
                    You could enter a time server in admin mode>Network>Detail Settings this will ensure the date/time is always correct.
                    • Salix
                      • Jun 2015
                      • 3
                      This is what I meant by a manual sync to google time server.
                      In any case, it ended up being an MFP board.
                      • tsbservice
                        Field tech
                        • 8028
                        So after I forgot it finally made a check and GXM-M1 is what I use lately(should include GHV-M1 fixes plus a ton of others).
                        • emujo2
                          • Mar 2017
                          • 1579
                          Guess what is on the new board?? A new battery. E
                          • copier tech
                            • 8182
                            Yes a 50p battery would have been cheaper & simpler to replace.
