C3300i freeze in boot
  • Tomesz
    • Mar 2020
    • 1
    #16
    Re: C3300i freeze in boot
    Hi!
    I have same problem, but I don't have any logo on boot screen. I would like to download the reset tool FW, with no luck.
    Is anyone have the AAJT0Y0-F000-GXX-22.exe ? Thank you guys in advance!
    • copier tech
      • 8132
      #17
      Originally posted by Tomesz
      Hi!
      We can supply this for you.
      Should you still require it please contact us via either web site below.
      โ€‹
      • rolls.bo
        • Sep 2014
        • 42
        #18
        hello, change SSD and follow the technical procedure to follow.
        If you are not a Konica certified technician on this model, do nothing and call a trained technician.
        The SSD disk is not a common disk but is specially made by Konica.
        Good luck
        • jwai
          • May 2018
          • 507
          #19
          I had this issue before and finally fixed it by replaced genuine SD card.
          BTW, other SD card ( for example scandisk, kingston etc... ) can be used on these machines ? ( C3300i , 246i etc... )
          • rolls.bo
            • Sep 2014
            • 42
            #20
            no, you must use an original Konica SD
            bye
            • and
              • Oct 2011
              • 96
              #21
              In my case recovery tool not start.
              Firmware not start.
              Removed the SD i can do firmware update and use recovery tool to check CPU was good.
              I changed the broken SD.
