C3300i freeze in boot
  • Sysco
    • Mar 2010
    • 43
    I have a C3300i which freeze in boot (KM logo) the line is 1/3 on total.
    This machines worked with perfect to friday.
    From friday it stucked to boot.
    I think it's an SD Card error.
    Can I boot it without SD Card?
    If I change a new SD Card it will be working, or I need something (format)?
    What stored in SD Card?
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: C3300i freeze in boot
    try firmware.
    • drowranger
      • Jul 2015
      • 122
      Please check knova and use AAJT0Y0-F000-GXX-22.exe to diagnose CPU board and storage board (MicroSD) . This new tool have the option to recover ssd as well.
      • Firmaware
        • 30
        For C3350 there is a tool for boot issue. I don't know work also with printer
        Gesendet von meinem SM-G980F mit Tapatalk
        • Sysco
          • Mar 2010
          • 43
          Originally posted by Synthohol
          try firmware.
          It's the G2-E9 fw version.
          • Sysco
            • Mar 2010
            • 43
            I will check this today.
            • Sysco
              • Mar 2010
              • 43
              And how can I checked it?
              • tsbservice
                Field tech
                • 8053
                He basically repeated what drowranger said. Download and use this tool/firmware its simple.
                Good luck
                • Sysco
                  • Mar 2010
                  • 43
                  I checked the diagnostic tool in the machine.
                  Nothing change.
                  It's freeze and not going to diagnostic menu.
                  I waited 5 minutes.
                  I checked the USB in other machine and it's work perfectly.
                  I don't know what I will change.
                  • Sysco
                    • Mar 2010
                    • 43
                    Nothing change.
                    I waited 5 minutes.
                    Attached the photo.
                    • copier tech
                      • 8200
                      Attached the photo.
                      It can take a few attempts to accept the firmware tool.
                      Try another USB drive & format it to FAT32 & use a USB pen no larger than 4GB
                      Diagnosis Recovery Method For Bootup Issues.pdf
                      โ€‹
                      • tsbservice
                        Field tech
                        • 8053
                        [ATTACH]50063[/ATTACH]
                        Good luck on latest i-series to use mainly old 4GB drives. It's not gonna happen.
                        Boot stuck at 25% is known issue on bigger models(A3).
                        • Sysco
                          • Mar 2010
                          • 43
                          I will try today, but the other USB stick worked in other machines I think not is this the problem.
                          • Sysco
                            • Mar 2010
                            • 43
                            Ok, I tryed the other (2GB) USB stick, and same result.
                            The C3300i can't boot, freeze in the start logo.
                            The other USB stick is also working in other C3300i machine.
                            • Firmaware
                              • 30
                              I'll try with the reset tool.
