C3320i replenish paper while copying/printing
  • jwai
    • May 2018
    • 517
    Hello,
    One C3320i that occur this issue, checked paper empty sensor and actuator, replaced paper feed unit but no luck.
    Try to lift paper drawer by myself when paper is feeding, it seems better.
    Any suggestion about it? Thanks a lot.
    I have mp4 video for this issue, how to upload here?
  • tsbservice
    Field tech
    • 8052
    Try:
    The simple, quick and secure way to send your files around the world without an account. Share your files, photos, and videos today for free.
    • Tech09
      • Apr 2020
      • 147
      Does it feed well when the tray is full and starts to jam more as there is less and less paper in the tray? Check the Trailing Edge Guide Plate in the tray, it is supposed to push the paper up into the pickup roller.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4764
        I use WeTransfer all the time, great FREE file transfer service
        • jwai
          • May 2018
          • 517
          No jam and feed smooth, both less or much paper, same issue.
          • tsbservice
            Field tech
            • 8052
            Back end of machine there is a screw where you can adjust a bit rail to higher the paper tray.
            • jwai
              • May 2018
              • 517
              That's video.
              • jwai
                • May 2018
                • 517
                Only find screw on front side of item 5 " rail ".
                • tsbservice
                  Field tech
                  • 8052
                  Back side, remove PS, remove mains plug and rail cover(black plastic), loosen screw and move rail up by 1-2mm, tighten screw etc.
