Konica Minolta C258 custom paper tray seting
  • Paulo Borges
    • 16
    [Misc] Konica Minolta C258 custom paper tray seting
  • tsbservice
    Field tech
    • 8007
    Re: Konica Minolta C258 custom paper tray seting
    Hi, can you post a picture for better understanding?
      • 23006
      Are you implying that any paper tray on your bizhub C258 can identify non-standard paper sizes, under any circumstances? You can certainly PROGRAM non-standard paper sizes through the panel, but the tray will not be able to automatically identify non-standard paper sizes. =^..^=
      • Synthohol
        Certified Konica Expert
        • 5822
        make sure auto is unchecked
        • Paulo Borges
          • 16
          This is what I need the machine to do. Photos are from another machine.
          • Paulo Borges
            • 16
            I want to manually program non-standard sizes, but this funtion is unavailable on this machine.
            • Paulo Borges
              • 16
              Yes, is unchecked.
              • allan
                RTFM!!
                • 5462
                Sure there are no user authentication setup on the machine with some restrictions?
                Can always try and initialize user settings.
                Whatever
                • Paulo Borges
                  • 16
                  User authentication is not turned on in this machine. I did "clear all data" on service mode but did not solve the problem
                  • B0265
                    • Jan 2007
                    • 718
                    If you activate Engine FW DipSW 19 it's possible to select custom-size paper detection of the tray 1 and tray 2.
                    Beware that in earlier C258's the guides in the paper trays can only be set to fixed posistions.
                    • Paulo Borges
                      • 16
                      Thank you. I'll try that when I go back on the machine.
                      • Paulo Borges
                        • 16
                        Finally problem solved.
                        Dipsw 19 was already activated with Hex value value 80. Maybe it depends of other dipsw to allow custom paper size on trays 1 and 2.
                        The way it worked was by copying the dipsw settings of another machine that already had that function enabled.
                        I changed the folowing:
                        Dipsw n. previous Hex value changed to Hex value
                        10 02 04
                        25 40 B0
                        51 F0 00
                        72 04 00
                        125 02 00
                        146 00 30
                        157 20 00
                        175 00 02
                        226 00 90
                        227 80 00
                        230 08 40
                        One of them must have did the trick as now machine allow the use of custom paper size on tray 1and 2.
                        Unfortunally I did not had the time for change back one by one to identify the right one. Too late on the end of the day.
                        One of the changes must be related to the way the computer gets the machine state as now when we press get device information on the computer driver an error message pops saying "printers can not be conected. Check port definitions. The machine prints ok altough, even on custom size paper.
                        Thank you for all the help.
                          • 23006
                          Thanks for posting back, and collecting the appropriate data. We can work with that to narrow it down further. =^..^=
                          • tsbservice
                            Field tech
                            • 8007
                            10 02 04
                            25 40 B0
                            51 F0 00
                            72 04 00
                            125 02 00
                            146 00 30
                            157 20 00
                            175 00 02
                            226 00 90
                            227 80 00
                            230 08 40
                            Engine FW DipSW 19 doesn't have hex values. Those switches are either On or Off.
                            Anyway good job but it's not recommended to change software switch values without need.
                              • 23006
                              Here's the DIPSW's that I can trace back:
                              10 02 04 ???
                              25 Firmware Function Version 3.0: 40, to firmware function version 4.2: B0
                              51 Consumable Life Warning-do not show: F0, to display all: 00
                              72 Import/Export Function-enabled: 04, to disabled: 00
                              125 AirPrint-enabled: 02, to disabled: 00
                              146 Switching Paper Feed Mode-disabled: 00, to enabled 30
                              157 Airprint-enabled: 20, to disabled: 00
                              175 Serverless Pull Printing-disabled: 00, to enabled: 02
                              226 Scan & Fax Settings: 00 90
                              227 Hide Consumable Status-enable: 80, to disable: 00
                              230 Hide Consumable Status-enable: 08, to Prevent Sending To Wrong Destination: 40
                              The only one I know nothing about is DIPSW #10
