"8" series default home screen
  • copyman
    Owner / Technician
    • Sep 2005
    • 4710
    Is there a way to default to screen in attached picture instead of copy screen. After 1 min it goes back to copy screen. I poked around for 30 mins and could not find it. Sorry for being lazy but I need to wrap up this machine for delivery tomorrow. Thanks in advance
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5836
    yes
    ill look in a sec.
    i know its default screen somewhere
    is it utility, custom display settings, copier settings, default settings?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4710
      Thanks Synthohol but that only gives choice of basic copy or quick copy. I ended up finding in Admin mode, system settings, reset settings, system auto reset, main menu instead of copy. Set to reset after 1 min and it goes to menu screen. I will usually leave on copy screen and end user can select scan fax etc with hard keys but this machine didn't have the small labels identfying hard keys so wanted the choices on home screen. All good and another one out the door!
      • Synthohol
        • Mar 2016
        • 5836
        i wish i was able to be back in the game so all the screens would be fresh in my mind again.
        i used to know this stuff in my sleep.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4710
          I know it's hard to keep up with these settings, especially if your not in front of machines every day. I still have trouble remembering the settings as you can see from OP and I'm in front of machines every day! I've always looked at settings to be a salesman thing and not for the technicians to worry about.
