Yeah I have tried different belts with same result but am wondering if the gears inside the machine are not providing the lift to the belt properly
Bizhub c258 Faded on OP Side only
Dumping on laser needs to be properly cleaned after removing PH unit.
Just a thought as we use only OEM.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
usually its to do with the calibration of the drum itself, if you have a look at the drum, the adjustments on the black / k and colour is diffrent. image.png
although pic rel is a c250i, you can get the same issue
first look at whats circled in red, make sure the cyan one is diffrent to black, if it looks like pic below, then dissasemble the front peice (the blue plate you pull out the machine) then adjust whats circled in purple
image.pngComment
mrfuser It looks like one of the pressure springs to the right and left of the transfer roller are missing, or one of spring cradles is cracked. But if that was the case you would see the same fading when running Black halftones. May be worth a look anyway.
dfretgfddd.jpgLast edited by KMFLT3CH; 09-20-2024, 01:22 PM.Comment
its a dumb issue and a dumb fix, i presume you are using third party drums or chipped black drums?
image.pngComment
My Ricoh knowledge is slowly dwindling away at this point. Many things have been lost to time...Comment
