"8" & "i" series with "paper cut"
  • copyman
    Owner / Technician
    • Sep 2005
    • 4724
    The warehouse I buy my off lease equipment from sometimes has machines listed as "couldn't test paper cut installed". Is there a way to disable / uninstall paper cut on the "8" & "i" series so I can test them and maybe buy them?
    I did see something on this forum for the "8" series about initializing machine in service mode. Is this same procedure for the "i" series?
  • copier tech
    • 8176
    Yes, at the device simply log in as admin, go to authentication settings & turn it off.
    • shadow038
      • Jun 2015
      • 9
      If you can not get into admin mode, go into service mode, might have to use back door, format hdd/strg pwb
      • copyman
        Owner / Technician
        • Sep 2005
        • 4724
        Thanks for replies. Hope this helps others. I got into service mode with holding small button behind control panel (bottom button) while turning on. Entered service mode and uninstalled storage / hdd, cycled power and machine threw "D" code, went back into service mode and installed storage. Cycled power again and all good.
