bizhub c454 cyan lines
  • cristian74
    • Apr 2020
    • 5
  • Drivee
    • Nov 2020
    • 322
    Re: bizhub c454 cyan lines
    perpendicular lines? Are you sure that you use good word? Can you post a picture?
    • cristian74
      • Apr 2020
      • 5
      11.jpg[QUOTE=Drivee;1895269] linee perpendicolari? Sei sicuro di usare una buona parola? Puoi postare una foto? [/CITAZIONE]
      • Toxic
        • 698
        This is English speaking forum so it is easier for you to use Google translate than all of us here who will try to help.
        Regarding your problem i would swap places for cyan and magenta drum unit and see if lines change color.
        Did you do all clear data before instalation procedure?
        • cristian74
          • Apr 2020
          • 5
          I apologize, in fact I had written in English but my pc translated it into Italian, however yes I have deleted all the formatted data also ssd and hdd but the result does not change
          • tsbservice
            Field tech
            • 8020
            Print bird page if lines are not there make clear all data and repeat install setup from the beginning.
            • Drivee
              • Nov 2020
              • 322
              Yea, this is not a mechanic problem, it is something what say to printer that he print vertical lines.
              • Synthohol
                Certified Konica Expert
                • 5847
                those are the "lines of shame"
                repeat the initial setup procedure from scratch from the install guide. dont miss a step and that issue will go away.
                • cristian74
                  • Apr 2020
                  • 5
                  I did it at least 30 times but the result does not change, I printed the lists and then initialized all the data repeated the installation procedure but nothing changes, in printing it works well only in color copies does those lines
                  • tsbservice
                    Field tech
                    • 8020
                    Check ADF serial is written also redo Non-Image Area Erase.
                    • cristian74
                      • Apr 2020
                      • 5
                      done everything but the result does not change
                      • Albonline
                        • Sep 2008
                        • 1151
                        the initial setup procedure was not successfully completed! either its not being done correctly or the emmc board is faulty/from another unit.
                        • Grey
                          • 38
                          Simple fix.
                          Get a Pink Pearl Eraser from 1958.
                          Scrub off lines from Print Out.
                          Old Techs will have a laugh!
                          Or follow set up Install Document, and be sure to set exact Time.
                          Be sure to Tip your Waitress.
                          Grey
                          P.S. Have a Real Tech correct this easy fix...many need an easy call, to boost the Monthly Report.
                          • yurisan
                            • Dec 2007
                            • 118
                            Had exactly this issue with an A4 color MFP. And yes, it is a built-in security measure (according to tech support) that has to do with unauthorized reproduction of financial documents, including currency. The step in setup that MUST be completed is the setting of the correct time zone (set the date & time, while you are it). Viola, color scans now do not have evenly spaced lines every 10mm. Go figure! "Only from the mind of Minolta" as the saying goes.......
                            • elmaligno
                              Expert technician KM
                              • Oct 2009
                              • 302
                              You are right!
                              Correct setting up is mandatory
                              Field technician since 1994
