UK-211
  • M1963
    • Jun 2017
    • 54
    UK-211
    Greeting,
    error D-272 (defective) is reported to me on c258
    I took out the DDR2 sdram, after that it says D-271 (missing)
    I thought it was enough just to remove extend memory.
    is there a procedure for setting the memory (UK-211) and also for removing the memory.
    thanks
  • Synthohol
    Certified Konica Expert
    • 5799
    there may be another license \ UK-kit depending on that extra ram installed?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4621
      Are you sure you didn't remove the RAM that machine needs to work instead of the optional UK-211 RAM?
      • Synthohol
        • 5799
        ^^^^^^yeah, that too ^^^^^^
        • M1963
          • Jun 2017
          • 54
          Greeting,
          I thought to remove the additional memory because it is defective and the machine does not do any more demanding printing. I did not succeed, and as Sintohol said, there is probably a license.
          I installed SDRAM 2GB from the notebook and for now it works normally
